Go Back   40K Terra - Warhammer 40k Forums > Warhammer 40k > 40k Army Discussion > Tau
Old 12-03-2007   #1 (permalink)
Trooper
manacycler's Avatar
Rep Power: 1 manacycler is on a distinguished road
Default Fish of Fury help
So I've heard of this rule and its supposed to counter act CC attacks, but how does it work? I heard that tau fire warriors can fire 'under' the devilfish, but is it only them or can enemy troops fire back?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
manacycler is offline   Reply With Quote
Old 12-03-2007   #2 (permalink)
Lieutenant
Imperial Commander Gent's Avatar
Location: According to some I dont actually exist, or I am not a real person!
Rep Power: 2 Imperial Commander Gent is on a distinguished road
Send a message via MSN to Imperial Commander Gent Send a message via Yahoo to Imperial Commander Gent
Basically, load a fish with 12 fire warriors armed with pulse rifles. Park the devilfish in front of them and unload them 12" away from your enemies troops and unleash hell. The devilfish is a skimmer, so you can fire under it, but if your opponent tries to assault your squad, they will have to go around the skimmer, because if they were to go under it, they would enter its zone of control and thus can not move unless going around. It effectively gives you two turns of rapid fire fun!
"Insons insontis probo nusquam"
Record for 2007 (Starting from last Rogue Trader in February) (W/L/D)
Ordo Xenos Marines 4/0/0
Thousand Sons 5/4/0
Imperial Guard 1/2/0
Cado ex Venia Chaos Marines 3/1/0
Chaos Demons 0/0/0
Record for Battlefield 40k for 2007 (W/L/D)
12/3/0
Imperial Commander Gent is offline   Reply With Quote
Old 12-03-2007   #3 (permalink)
Emperor
Ikarus's Avatar
Chapter Master
Rep Power: 2 Ikarus has disabled reputation
Send a message via AIM to Ikarus
[Tau Tactics] Fish of Fury Formation
let me know if that helps any.
HORDES: TROLL BLOOD: 1.250k Pts
BATTLEFIELD 40k: VOTE VOTE VOTE
Ikarus is offline   Reply With Quote
Old 12-03-2007   #4 (permalink)
Trooper
manacycler's Avatar
ohh...so that does mean the enemy can still fire at my tau....so wait, then how this useful when going against bolter armed marines or any other unit with good ranged?...or is it not and the fish of fury was meant for CC orientated opponents?
Old 12-03-2007   #5 (permalink)
Lieutenant
It works pretty well against enemy ranged troops because if they do decide to shoot you, target priority checks are in order and there isnt much left after you do a fish of fury man. Dont worry about it so much!
Thousand Sons 5/4/0
Chaos Demons 0/0/0
12/3/0
Old 12-03-2007   #6 (permalink)
Emperor
Ikarus's Avatar
Chapter Master
Yes. Hence this is a counter Close combat maneuver.
EXCEPT
when you use it offensively, you can drive up to your enemies, and undeploy and unload double tap shots to your enemy.
Key goal is to NEVER go unsupported. The whole tau army must function as one, or it will fail.
The Following 2 Users Say Thank You to Ikarus For This Useful Post:
Old 12-03-2007   #7 (permalink)
Lieutenant
He has a point, dont do things unsupported!
Thousand Sons 5/4/0
Chaos Demons 0/0/0
12/3/0
Old 12-03-2007   #8 (permalink)
Emperor
Ikarus's Avatar
Chapter Master
Yes, you go in supported, present a lot of targets and threats,
You mess with opponent's target priority, then he will either:
SPREAD FIRE (Which is what you want)
or
Focus FIRE (Which could mean you have less things dead.. but important things dead.. could be bad)
So make your whole army a threat.
Tis the first step to powergaming.
Old 12-03-2007   #9 (permalink)
Corporal
Celestial Guardian's Avatar
Rep Power: 1 Celestial Guardian is on a distinguished road
Send a message via AIM to Celestial Guardian
the functionis tow fold.
1) to protect your firewarriors/pathfinders by putting another target in the way to force a priority check to shoot the unit
2) to protect your firewarriors/pathfinders by maing the unit unavaible for assault.
As Ikaurs pointed out,m if used correctly with backup (often putting tow units close enough to each other will give more firepower to your units and double the space around to your units (triple if both fishes are turned sideways)) the effects can be quite devastating to even the mighty space marines.
The priority tests are nice when forced, but are able to be passed most of the time. The real benefit is getting as many shoots off as you can and keeping your opponent from assaulting you.
From Necromunda to Apocalypse, your one stop for fun!
Celestial Guardian is offline   Reply With Quote
Old 12-04-2007   #10 (permalink)
The Thing That Should Not BE
iNsOmNiAc'S dReAm's Avatar
Rep Power: 1 iNsOmNiAc'S dReAm will become famous soon enough
The point is to be the first to get into rapid fire range and draw first blood and thin out your oppenents numbers. You just pretty much screw up your oppenent by putting him between a rock and a hard place. He either ATTEMPTS to assault around your devil fish, or he rapid-fires back at ya and basically forfits his ability to assault you anyway.
Drax says:
Insomniac's Dream - master of a thousand inner conflicts
iNsOmNiAc'S dReAm is offline   Reply With Quote
Old 12-04-2007   #11 (permalink)
Filthy, Dirty Radical
experiment 626's Avatar
Rep Power: 4 experiment 626 has a spectacular aura aboutexperiment 626 has a spectacular aura about
just be very warry of enemy deep strikers who can land behind your near-impregnable formation!
for example, my 55pts heavy flamer sentinel w/armoured crew compartment makes an abolsute mess of any 'fish of fury' manouver!
similarly, anything that can deep strike and bring those template and/or large blast templates to bear will murder you... (oh, and fear the necrons with their viel of darkness - it works a real charm too!)
to counter this, you can always leave some crisis suits parked slightly back from your fire warriors, (ie: within about 6" - 8" of them). this makes the deep strike a very risky proposition as no deep strikers cannot come within 1" of an enemy model.
granted there will still be those really psychotic players who'll take the risk like myself, but i find that the vast majority of players look upon deep striking as far too risky in anything but the 'ideally perfect' conditions! (ie: they have at least 13" clearance in every direction or else they have a teleport hommer or similar within about 6" of where they want to be!)
cheers!
"Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!"
- Inquisitor Odion
experiment 626 is offline   Reply With Quote
The Following User Says Thank You to experiment 626 For This Useful Post:
Old 12-04-2007   #12 (permalink)
Captain
Warmaster Romulas's Avatar
Rep Power: 1 Warmaster Romulas is on a distinguished road
its best against isolated units like fast movers rolling up your flank
it works best with 2 squads in fish
i like squads of 12 and i use the drones from the fish to pin the targets.
if done right you can pin a squad and unload 24 shots into it
if they are unable to move the next turn and survived the first barrage you can unload another 48 into them
dont forget to mark them with the markerlights
its very deadly but requires good timing and measurements
if you are off
you can loose 2 squads and 2 fish very fast
""A true patriot is a lover of his country who rebukes and does not excuse its sins."
Frederick Douglass
* new items added 4/6/08 *
** tomb king army up for trade**
Warmaster Romulas is offline   Reply With Quote
Old 12-04-2007   #13 (permalink)
Trooper
manacycler's Avatar
well thanks for all the advice, I get how to do it now...but now I don't need to ^^;;
I bought a rapid insertion force instead of a battleforce so, instead I now have 9 crisis suits.
Old 12-04-2007   #14 (permalink)
Corporal
Biadetic's Avatar
Rep Power: 1 Biadetic is on a distinguished road
Send a message via MSN to Biadetic
cant you only use them in Apocalypse though?
Biadetic is offline   Reply With Quote
Old 12-04-2007   #15 (permalink)
Trooper
manacycler's Avatar
you're supposed to only use them in apoco because nine crisis suits are three elites, which completely fills the force org chart and are probably worth a lot of pts (I haven't calculated them yet). But they seemed so cool so I bought it.
Since kenshin and I are still playing with force org chart in play, I had to move some troops around to allow them in, I'm also converting one to be a commander.
Old 12-05-2007   #16 (permalink)
Corporal
Biadetic's Avatar
makes sense
do you have much in terms of tau? im guessing you have enough if you decided 9 crisis suits over a battleforce
Old 12-05-2007   #17 (permalink)
I have a Farsight Army, total of 16 or so battle suits in all including Farsight himself and his 7 body guards
Drax says:
Old 12-05-2007   #18 (permalink)
Trooper
manacycler's Avatar
I'm mixing them into a chaos army, so they fit ok enough.
Old 12-05-2007   #19 (permalink)
Corporal
Biadetic's Avatar
what? :S for apoc?
Old 12-05-2007   #20 (permalink)
Trooper
manacycler's Avatar
umm, sorta...kenshin and I don't have big enough armies for that yet, but we've already started mixing armies.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
