Go Back   40K Terra - Warhammer 40k Forums > Hobby Discussion > Tutorials > Painting Tutorials
Painting Tutorials A place to sharpen your brush skills...
Old 02-07-2008   #1 (permalink)
Adeptus Arbrites
iNsOmNiAc'S dReAm's Avatar
Rep Power: 1 iNsOmNiAc'S dReAm will become famous soon enough
Default Painting Tutorial: HOT Lava Bases
Well ladies and gents, ALOT of you have demanded it and I think I put it off long enough =P, so I finally got my act together and decided to put up my long awaited lava base tutorial. This will be a pretty lengthy tutorial and I will probably have to do this in multiple post.
First things first, is base construction. The materials you will need are:
-cork
-cork in sheet form
-PVA glue ( white elmers glue works just fine )
-an old paintbrush
-a hobby knife
-blank bases
I love to work with cork for my bases. Its cheap and easy to use and, for this project it has the right kind of texture I want for my lava rocks. Cork can be found just about anywhere and for the sheet cork you can find pretty good sized rolls for less then $4 bucks, enough cork for 3 armies and then some.
Step 1:
Take some of your sheet cork and break it up into random shapes of various sizes, be sure to have a few ' large ' peices suitable for you mini to stand on. Then take your hobby knife to your other peice of cork and break it up into tiny peices like so.
Step2:
Arrange your cork around your base, being sure to leave large cracks and spaces between rocks for your lava flow. Dont be afraid to stack rocks to add height and depth to the base, just be sure to leave enough of a flat surface for your mini to stand on. Generously 'paint' on your pva glue to the bottom of each peice and press and hold it firmly in place till it dries.
Step3:
To help the cork recieve paint better, I like to paint over all cork surfaces with some watered down PVA glue. Once that dries Primer the entire base with chaos black. and then you are ready for painting.
continued in next post
iNsOmNiAc'S dReAm is offline   Reply With Quote
Old 02-07-2008   #2 (permalink)
Adeptus Arbrites
Default Re: Painting Tutorial: HOT Lava Bases
Part 2
Before we continue with painting lets study a picture of a real lava flow...
As we see here Lava isnt red like how it is in cartoons, but HOT WHITE and darkens in color as it cools and eventually cools into black rock.
To achieve this look we will need these colors and materials:
-Scab Red
-Red Gore
-Blazing Orange
-Sunburst Yellow
-Skull white
-Chaos Black
-Codex Grey
-Eye dropper filled with clean water
-Cardboard Backed Glass Pallet ( or a wax paper if you prefer )
Step 1:
Lay down the foundation with some scab red. Be sure to get in every little crack and crevis, and dont worry too much about neatness at this point.
Step 2:
put a few drops of Red Gore on your pallet and thin it down to a skim milk/cream like consistancy with water from your eye dropper. This is very important as it will give your paint some translucency, and will allow some color from below show through. Paint over most of the lava flow, just leaving the very edges around the rocks alone.
Step 3:
Take your mixture and add just a bit of Blazing Orange, and thin it down some more if need be. I cant tell you the exact mixture as I mix by eye but at this point it should be much more red then orange. From the edges inward you want to paint in smaller and smaller areas, leaving the last color showing around the edges.
Step 4:
Add 2 drops of Blazing orange to your mixture. At this point we are going to try and simulate the flow of lava by painting streaks that follow the curvature of the rocks.
Step 5:
Add 1-2 drops of Blazing Orange and 1 drop of Sunburst Yellow, remember to keep your mixture thinned. Now we are going to detail the flow of lava a bit more. Start by highlighting what youve done in step 4, and add a few smaller lines aswell.
Step 6:
Make a thinned down mixture of Sunburst yellow and blazing orange, and highlight what you've done in step 5.
Step 7:
Highlight the " hottest " part of the lava with a straight mixture of Sunburst yellow and skull white.
Step 8:
Hightlight your hot spots with a small dot of thinned down skull white, to really give it that 'glow'.
Step 9:
Youre lava is almost finished, but right now its just a lil too orange.. To dull that down a bit and to blend together your shading we need to do a glaze with your base red. To do that, take some red gore and thin it down till its almost like colored water. Then just glaze over all of the lava entirely, you may have to do 2 coats.
Step 10:
The final step would be to clean up your rocks some, and LIGHTLY dry brush over them with some codex grey. To really bring your base to life and give the illusion that its really glowing you could do some object source lighting on the edges of the rocks.
Well Im hope this gives you folks an idea of how I accomplish my lava bases. This is only one way of doing it and is just a lil something for you to expand on. Sorry if the pics got a lil blurry in the end, but hopefully you found this tut useful and could understand my mindless gibberish regardless =P
Good luck and have fun with it.
( WARNING!: This product has been known to cause cancer in the state of California, as well as unexpected and unexplained pregnancy in test subjects. If rash or excessive hairiness developes, discontinue use and seek veterinary assistance IMMEDIATELY!)
Drax says:
Insomniac's Dream - master of a thousand inner conflicts
The Following 4 Users Say Thank You to iNsOmNiAc'S dReAm For This Useful Post:
Old 02-07-2008   #3 (permalink)
Corporal
Petey1016's Avatar
Rep Power: 1 Petey1016 is on a distinguished road
Send a message via AIM to Petey1016 Send a message via Skype™ to Petey1016
ooo this way looks easier than Davidus' i may have to try it.
Nice tut
"Drink Deep of Victory and Remember the Fallen"
Horus: "We are talking about the dude who bludgeoned me to death with his EGO!" -Horus Talking About the Emperor
Petey1016 is offline   Reply With Quote
Old 02-07-2008   #4 (permalink)
Hairy Hunter
Krom_stormbrow's Avatar
Rep Power: 1 Krom_stormbrow is on a distinguished road
Send a message via AIM to Krom_stormbrow Send a message via MSN to Krom_stormbrow
+rep for you.
Nice tut. To red for my taste, I think you should have gone more yellowy - white.
None the less, I like and executed well and I will find reason to use this.
Krom_stormbrow is offline   Reply With Quote
Old 02-07-2008   #5 (permalink)
Lieutenant
Mart007's Avatar
Battle Brother
Rep Power: 1 Mart007 will become famous soon enough
Send a message via MSN to Mart007
Lovely Tut, you know I'm going to find this useful fo my Avatar! thank you and +rep+
Follow my log (dont worry, it's a project log)
http://www.40kterra.com/forums/showthread.php?t=3223
Mart007 is offline   Reply With Quote
Old 02-07-2008   #6 (permalink)
Pancake Madman
Rellik's Avatar
Battle Brother
Location: Wichita Kansas, or as we like to call it the dub k
Rep Power: 2 Rellik has a spectacular aura aboutRellik has a spectacular aura about
Send a message via AIM to Rellik Send a message via MSN to Rellik
very nice! pa'oe'oe( sp? ) huh
This is Rellik and i approve this message
www.myspace.com/makaala_d come on by and visit
Rellik is offline   Reply With Quote
Old 02-07-2008   #7 (permalink)
Master Procrastinator
hairyyahoo's Avatar
Honor Guard
Location: As a figment of my own deranged imagination, i don't actually exist anywhere. Or London, UK.
Rep Power: 5 hairyyahoo is a jewel in the roughhairyyahoo is a jewel in the roughhairyyahoo is a jewel in the rough
i'd have finished it at the stage before the glaze personally as that stage looks more like the photo you showed us.
+rep, big time!
hairyyahoo is offline   Reply With Quote
Old 02-07-2008   #8 (permalink)
Just A Regular Joe. Again
SteveBerenyi's Avatar
Rep Power: 4 SteveBerenyi has a spectacular aura aboutSteveBerenyi has a spectacular aura about
Send a message via AIM to SteveBerenyi Send a message via Yahoo to SteveBerenyi
+ rep from me as well!
WIN/DRAW/LOSS On The Battlefield
5 / 1 / 4
SteveBerenyi is offline   Reply With Quote
Old 02-07-2008   #9 (permalink)
Lodge Member
Brother Warchild's Avatar
Rep Power: 3 Brother Warchild has a spectacular aura aboutBrother Warchild has a spectacular aura about
Send a message via AIM to Brother Warchild Send a message via MSN to Brother Warchild Send a message via Yahoo to Brother Warchild
Nice job,gonna have to give this one a try.
Originally Posted by hairyyahoo View Post
sweet mercy of all things sweet and merciful! that's insane!!! warchild is now the official 40kterra nutjob
My Stuff ( links )
Lupercal! A truescale Luna Wolf's W.I.P
Wolves of Fenris A Space Wolve's W.I.P
Legion of the Damned W.I.P
Tricks of the Trade
MY Trade Stuff @http://www.rogue-market.com/index.php
Brother Warchild is offline   Reply With Quote
Old 02-07-2008   #10 (permalink)
Trooper
Zeb[edee]'s Avatar
Rep Power: 1 Zeb[edee] is on a distinguished road
Send a message via MSN to Zeb[edee]
Tyvm! I would give you rep but i cant =\
Meh, Thanks =D
"World of Warcraft is much like a social life. Everyone finds a better game after a few months."
Zeb[edee] is offline   Reply With Quote
Old 02-07-2008   #11 (permalink)
Adeptus Arbrites
+rep, big time!
That was a bad pic actually =P, I took it while the glaze was still drying. It looks much better when its completely dry, and its a necessary step to effectively blend all the colors together.
Drax says:
Old 02-07-2008   #12 (permalink)
First Chaplain
Lord Commander Erus's Avatar
Honor Guard
Rep Power: 6 Lord Commander Erus has a spectacular aura aboutLord Commander Erus has a spectacular aura about
Veyr nice tut! +rep, and I will have to remember this in the days to come.
"Truth is infinite. It is defined by our perception of the facts; therefore we can never know absolute truth, we can only guess at it. A man who knows he has done no wrong needs no redemption, regardless of the views of others. The truth is what he believes it to be. A man who knows he has done wrong can only be redeemed when he chooses to forgive himself."
-Lord Inquisitor Balkoth
Black Saints Adeptus Astartes Chapter
Lord Commander Erus is offline   Reply With Quote
Old 03-20-2008   #13 (permalink)
Trooper
Colonel Marbi Chora's Avatar
Rep Power: 1 Colonel Marbi Chora is on a distinguished road
Send a message via Yahoo to Colonel Marbi Chora
Oooooooh, shiney base.... I have to try this out!
So the Eagle Keens- My 40kterra IG project log!
http://www.40kterra.com/forums/f148/...html#post97663
Originally Posted by all-lucky7777 View Post
First one to call me creepy gets a big hug!
for the love of all the gods woman, don't read the manual!?! just press random buttons til something works
Colonel Marbi Chora is offline   Reply With Quote
Old 03-20-2008   #14 (permalink)
Sergeant
TerminatorinHell's Avatar
Rep Power: 1 TerminatorinHell is on a distinguished road
this will be awesome for my to be ryoto inq scale model
House: we have a bullet wound in exam room one
Cameron: Did someone shoot him?
House: No they threw it at him
House MD is awesome
TerminatorinHell is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
