| Conversion and Modeling Base Learn how to customize, pose, and convert your favorite models! |
| The Dark Apostle ![]() ![]() ![]() ![]() | Hello! ![]() The biggest model I've ever built is without a doubt the most fun to build also. So how do you start on the Brass Scorpion? first things first: you need two Defilers. duh! other essentials: modeling knife, clippers, plastic glue, green stuff, you know the drill. The Tail of course, the most noticable and unique thing of the scorpion is the tail. the tail is built using two defiler claws and your scorpion cannon. ![]() you only need to use one of the back halves of the claw that attaches to the defiler itself (on the left here) and two of the other ones. ![]() you'll notice that the front half of the claw has on one side a slot were the claws themselves go in and on the back a single gear-like device. what you will need to do is cut the back gear-like thing on one claw so that the holes will line up directly. The Gun now if youre going to do it as i did, with the hellblaster volley gun, heres how to do that. if you are going to use the two-twin linked reaper auto cannons, as it is in the picture, I'll explain that later. for the volley gun, glue it together as normal but dont put on the wooden back on it (duh) cut a slot in the claw were the gun will go. the gun is going to be lined up with three barrels along the top. cut it so that the back of the barrels will line up flush. ![]() glue the gun on now. as for the cover, i used two of the leg covers side by side. one side is bigger then the other, so make sure you did it evenly. the bigger sides should go over the gun so it'll fit ![]() to put the cover on, you'll need to cut the blades off of the top. i put them back on in the slits of the cover. ![]() now glue the two halves together ![]() i stuck the back of a thin back of a file through the center hole so it wouldnt move around. The Body take the two defiler bodies. cut the reactor portion off of the front one right behind the last leg socket. file it down so they line up straight and flush, but dont glue together yet. you need to put on the demolisher cannon and hellfire cannons first ![]() youre going to have a big divot in the middle. i used a claw covering to cover it up.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I am a leaf on the wind Watch how i soar To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Dark Apostle ![]() ![]() ![]() ![]() | Body Guns the hellfire cannons are easy. take the heavy flamers, assemble as normal. cut off the nozzle. now take four of the chaos weapon muzzles and glue them on UPSIDE DOWN the hellfire guns are going to be glued on the bottem of the front body upside down, so with the muzzles upside down on the gun, it looks right side up when finished. i used green stuff. they shifted when i took the picture, but i put em back. ![]() now for the demolisher cannon cut off the circular portion of it like so ![]() shave off parts of the front body and the demolisher cannon so that it fits in snug and flush. and the barrel decorations like normal. glue the cannon on, then glue the two body halves together ![]() now to attach the tail. cut off portions of the ball thing on the back so that it will fit snug. if you used any metal in the tail (a metal gun for example) you should pin it. you may want to magnetize it as well. ![]() Legs n claws ok now! youre almost done. for the legs, glue them and the claws on like normal. you will have five sockets. 1(rear, tail)-2-3-4-5(front, claws) i glued mine in like this: 1-X-3-4-claws with that break not in the back, it balances it out so that the tail or the claws dont make it tip forward. why GW sucks now when i got my second defiler today, IT HAD NO LEGS none at all. i got two body sprues and no leg sprues. but because i had an extra body sprue, i took the extra claws and made them into legs by cutting off the blades and bottem claw like this ![]() The Brass Scorpion ![]() now youre done, add in any khorny decorations you might want. i used a sheild from the WFB mounted khorne lord on mine, as well as a khorne icon on top of the gun. this is the biggest thing ive ever built. ![]() its four carnifexes! a landraider and a half! ![]() its insane. happy building, and of course never forget. BLOOD FOR THE BLOOD GOD!!
| The Following 11 Users Say Thank You to Dan296 For This Useful Post: |
| Corporal ![]() Join Date: Sep 2007 Location: south of heaven, north of hell
Rep Power: 1 ![]() Thanks: 10
| FRIGGIN SWEET!!!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Necrons never truly die! Quote:
TRIFARCE POWER FTW! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |
| | #4 (permalink) | |
| On The Warpath! ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: As a figment of my own deranged imagination, i don't actually exist anywhere. Or London, UK.
Rep Power: 5 ![]() ![]() ![]() Thanks: 178
Blog Entries: 1 | great tutorial, well laid out and very easy to follow. stirling work indeed ![]() a nice shiney +rep for you young man.
__________________ Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |
| I Have A Fish In My Pants ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Butte, Montana
Rep Power: 3 ![]() ![]() Thanks: 207
Blog Entries: 5 | OMFG dan that is awesome! thanks and + rep Thanks for the tutorial, +rep for the awesome assembly!
__________________ WIN/DRAW/LOSS On The Battlefield 4 / 1 / 4 VOTE To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Ends April 22 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Ends April 24 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. PLEASE VOTE!!! |
| The Emperor's Mercy ![]() ![]() ![]() | yea so dan...that thing is amazing. excellent work ! rep for you :]
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SHOWBREAD. ANOREXIA/NERVOSA. MAY THIRTEENTH TWO THOUSAND EIGHT. |
| Sergeant ![]() | good tutorial, but if you don't mind me saying, you left far more of the body pieces than was needed, you've got an extra set of leg sockets that look strange and defunct. If you'd cut off the front of the rear body piece then you wouldn't have this problem. That point aside, excellent model!
__________________ My Projects: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. My Reviews: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Other: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Blog Entries: 5 | no, they have 6 plus the tail. and the mandibles. so yea, 8 i guess.
| The Dark Apostle ![]() ![]() ![]() ![]() | ok, i messed that up a bit and forgot to talk about that: since i didnt get the legs, i could only use 6 sockets. however, with 2 sets of legs normally you will have 8 legs to put in there. though its an extra set, all you have to do to do it normally is to cut off another socket, then cover it up somehow (a claw or leg cover...or two) pretty simple i intented to fix it right away but my internet went awry
| | #12 (permalink) | |
| Adeptus Primarch ![]() ![]() ![]() Join Date: Nov 2006 Location: Somewhere between Crewe and Stoke in the Midlands
Rep Power: 2 ![]() Thanks: 72
Blog Entries: 1 | Quote:
![]() Heres another one- Scorpions dont have tails...that 'tail' is more correctly the lower abdomen. Wow! hehehe
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Battles Updated Daily (Enter via Insignia) | |
| The Dark Apostle ![]() ![]() ![]() ![]() | so i played a test game with it today and WOW my new favorite model. ever. 3k points eaters vs. black templars. the templar player used 'suffer not the unclean' with an armoured spearhead strat. he rino rushed me while I, uncharacteristicly, stayed put in the buildings covering the table. however, the dogs were let loose. i sent the scorp towards his armoured spearhead (three land raiders, in this case 2 crusaders 1 normal) the scorp demolished almost an entire crusader squad in the shooting phase with its cannon and hellmaw guns (cannon is heavy 10, hellmaw is normal template. both are s6 >>AP3<<) and then stomped the rest to death. over the following turns he rampaged through their army until getting into combat with their command squad and sword bretheran. the sheet amount of powerfists finally brought it down. however, now the fun part. 3d6 strength 9 ap1 explosion!! rolled a 9. not bad, killed almost everything it touched!! its a monster! and ive unleashed it on 40kTerra! mwahahahaha!!!
| Sergeant ![]() Join Date: Jul 2007 Location: Falls Church, VA
Rep Power: 1 ![]() Thanks: 32
| Thats beyond awesome, great work.
__________________ Valhalla - Deliverance Why've you ever forgotten me To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 40k Chaos: 1250 Points Imperial Guard: 650 Points Space Marines: 650 Points Eldar: 650 Points Daemon Hunters (add on): 250 Points Fantasy Orc & Goblins: 1000 Points Ogres: 700 Points |
| The Dark Apostle ![]() ![]() ![]() ![]() | now to paint it! going to take a long time....and alot of red...
| | #16 (permalink) |
| The Dark Apostle ![]() ![]() ![]() ![]() | so ive started to paint the thing...i want it to be done by saturday to enter it into an apocolypse battle! (i never play with a model that isnt done...rule of thumb!)
| Arch-Magos ![]() Join Date: Aug 2007
Rep Power: 1 ![]() Thanks: 36
| Yeah, it looks sick when facing you, but from the aerial view it looks too long.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| | #21 (permalink) |
| The Dark Apostle ![]() ![]() ![]() ![]() | i finished the painting about 2 weeks ago, thought i'd posted pics ill get on it then ![]()
| | #22 (permalink) | |
Blog Entries: 1 | good man ![]()
| | #23 (permalink) |
| Pancake Madman ![]() ![]() Join Date: Aug 2007 Location: Wichita Kansas, or as we like to call it the dub k
Rep Power: 1 ![]() Thanks: 80
Blog Entries: 5 | awesome job. cant wait to see it painted
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. This is Rellik and i approve this message To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. come on by and visit |
