| Conscript ![]() Join Date: Oct 2007
| And if so, did it work like you hoped or get destroyed to easy?
__________________ Clothes make the man. Naked people have little or no influence on society. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mark Twain To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Lieutenant ![]() | It can work for ya, but it will catch a lot of bullets! that is the biggest thing to be worried about cus it wont survive long in the open!
__________________ "Insons insontis probo nusquam" Record for 2007 (Starting from last Rogue Trader in February) (W/L/D) Ordo Xenos Marines 4/0/0 Thousand Sons 5/4/0 Imperial Guard 1/2/0 Cado ex Venia Chaos Marines 3/1/0 Chaos Demons 0/0/0 Record for Battlefield 40k for 2007 (W/L/D) 12/3/0 |
Rep Power: 4 ![]() ![]() Thanks: 20
| if you do ever intend to use a basilisk to fire directly, give it the armoured crew compartment... the really huge weakness of the bassie is it's weaker side armour & it's open-topped stat. negating that +1 to all damage rolls can mean the difference between a simple 'immobilised' result or a 'wreaked' result! cheers!
__________________ "Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!" - Inquisitor Odion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Arch Heretic ![]() ![]() Join Date: Jul 2007 Location: Cawood, KY
Rep Power: 2 ![]() Thanks: 69
Blog Entries: 1 | Bad ideal. You should always hide Basiliks behind cover and bombard away! I used the indirect fire with a Defiler (3rd ed. rules), and it was pretty effective, but I'm terrible at guess range! If someone is really good at guesstimating range, indirect Ordanace weapons can be effective not only when they hit, but they make your opponet stick real close like to cover, thus slowing them down.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. “Nothing you can lose by dying is half so precious as the readiness to die, which is a man’s charter of nobility.” George Santayana. |
| | #6 (permalink) | |
![]() you delcare target as normal, then measure to make sure the target is; a) over your minimum range. b) still within your maximum range. if either range is off, then your shot auto-misses and no scatter/template is used. otherwise, you scatter as per the rules for firing indirectly. (ie: roll 2D6 & pick highest.) the main reason i see for taking a direct firing bassie is if you're playing on 4x4 table... with the huge minimum range for the bassie's indirect fire, you'll typically need direct line of sight after turn 2 if you want to shoot anything! cheers!
__________________ "Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!" - Inquisitor Odion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |
| | #7 (permalink) | |
Blog Entries: 1 | Quote:
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. “Nothing you can lose by dying is half so precious as the readiness to die, which is a man’s charter of nobility.” George Santayana. | |
| The Emperor's Mercy ![]() ![]() ![]() | i want to guess that it doesn't upgrade the armor, just makes it "closed-topped." wait, does this FW one have a different set of rules from simply a bassie with an armor compartment ? intriguing... :P
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SHOWBREAD. ANOREXIA/NERVOSA. MAY THIRTEENTH TWO THOUSAND EIGHT. |
| | #9 (permalink) | |
the rules for 'guess' range weapons were changed in the 4th edition rulebook due to the following reasons; a) it's simpler and allows for faster game-play b) so many people were cheating under the actual "guess the range to the intended target" rule of 3rd edition! cheers!
| I was asking because I was thinking of using some for my IG. My IG army's homeworld is going to be one that fights nid's alot, and thought fluff and gameplay-wise they might be alright against a nid army..... maybe.
| | #11 (permalink) | |
| The Witchhunter ![]() | you wouldn't need to fire directly at a nid swarm tbh, in all likelyhood, even if you scatter the maximum 6" you will probably still hit something. in fact, fluffwise, heavy vegetation is the order of the day when a hive fleet comes a knocking, so plenty of indirect fire would help you, and slow them down. Basilisks and morters should serve you well
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I have brought more soldiers than you! | |
| Major ![]() Join Date: Nov 2006 Location: Oregon
Rep Power: 2 ![]() Thanks: 217
| Theoretically a Basilisk without indirect fire might be a good fire support unit for your Guardsmen squads. Of course I've never tried this, so if I'm wrong please slap me.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Don't To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. the Killer! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Trooper ![]() Join Date: Nov 2007
Rep Power: 0 ![]() Thanks: 7
| well i usually play on huge tables without much cover and my bassilisk is the only thing in range i always use direct fire
__________________ whats the point of a few billion imperial guardsmen if they are not to die for their emperor. Whats the point of thousands of leman russ if they dont explode for the emperor. Long live the emperor and the super heavies!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. pic of the new forge world reaver The avatar is what happened to your house |
| Soldaten ![]() ![]() ![]() ![]() | I used one somtimes, but two most of the time. They seem to be effective but for the most part I am switching over to Leman Russes (2) and a Griffon. I like the griffon because its cheap indirect fire, and the Leman Russ' armour cant be beat
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Not just a Tale but a Legend Hey BTW Need Advice on some Games?! Heres what I play: Imperial BFG, Imperial Guard, Space Marines, Sisters of Battle, Orks, Tau, Chaos Marines PP- Khador, Cygnar No Im not a nut, I just live in the past: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Corporal ![]() Join Date: Jan 2007 Location: Back in NYC
Rep Power: 2 ![]() Thanks: 3
| Firing a Basilisk indirectly is just called 2nd turn. I wouldn't recommend taking basilisks without it in larger games because you might need a very opportunistic ordnance blast in a place where you cannot get to. 4'x4' games where you will probably have no indirect fire after the first turn you can afford to save the 25 points, depending on the army you are facing.
__________________ "Only the insane have strength enough to prosper, only those that prosper may truly judge what is sane." |
| | #16 (permalink) |
| Primer ![]() Join Date: Jan 2008
| If you are going to not have the inderect option, you need to run at least two if not three. Spreads the shots coming in at them a bit and who doesn't like three Ordance templates anyway! I'd second the armored compartment if you have the points for it.
__________________ Purge the Unclean! |
| Corporal ![]() | yes I have and No it did not I did it a few times and I have come up with a way to make it work. heavy weapons teams lascannonx3 are the key positioning is the key you want to start as close as you can to a benificial position. on the bright side it is a ap2 weapon and without guess range it is not guess range ![]() |
| | #18 (permalink) | |
| Rabid Ranter ![]() Join Date: Nov 2006 Location: Im not entirely sure. I think im stuck inside an alternate reality where im blue and the sky is me.
Rep Power: 2 ![]() Thanks: 36
Blog Entries: 1 | I suppose it might work if you gave the bassie some support on the sides. I don't know, a meatshield. You know. Imperial Guard. They're a good meatshield. But other than that I can't see a way that the bassie can survive. It'd be taken out pretty quickly if flanked.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 'Heretical filth... I am an Inquisitor... I AM YOUR JUST LAW!' - Inquisitor Julius Sedaire To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Quote:
