| Past Competitions The results of previous 40k Terra Competitions. |
| Tyrant of Moray ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Eye Of Terror
Rep Power: 3 ![]() ![]() Thanks: 19
Blog Entries: 4 | Right Im in-will post picture of proof of purchase ASAP Lets just say pre heresy for the moment!! Heres the proof ![]() Ill add some WIP pics as I can through the next two days!!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Experts in Siege Works....we also do Patios and Drives To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Perturabo; 01-28-2008 at 03:27 AM. Reason: added proof of purchase |
| Corporal ![]() ![]() | 3 days to go... you better FLY through this conversion
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Blog Entries: 4 | The goats have been sacrificed and suitable supplications to the dark gods made!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Experts in Siege Works....we also do Patios and Drives To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Blog Entries: 4 | Right here goes (I apologise for the shockingly bad photos but my camera died just as I started taking piccies and Im havin to use my phonecam till the batteries recharge). I am planning to make a pre heresy style Terminator. I needed to find as many parts as I could from the boxset without imperial eagles or post heresy style markings (purity seals,crux terminus etc). having done this I then set about filing of the few markings I couldnt get away with-was lucky on this out of all the stuff I wanted only had to file one purity seal from the legs!! Next the head was the most important part-its the focal point of the mini-time to do some experiments I felt ![]() Nice as these are I didnt feel they were quite pre heresy enough (the one on the left is based on one the early Terminator models and the one on the right still looks too much like a Chaos Marine-Ill be using him elsewhere!) So using a Chaos Marine head (Im a bit short on spare marine heads at the moment) realy realy trimed down and plenty of plasticard I came up with this!! ![]() Next is the legs-these are easy as they are just a case of modding the plating that makes up the legs to make it look more arcane. Need to do some arm prototypes as well as i see them being a very in depth build!!
| Lieutenant ![]() | Perturabo, using slaves is called cheating ![]() But i hope you get it done on time ![]() Can`t wait to see how it turns out.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Corporal ![]() ![]() | ![]() Fix it! I want to see this.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Nanolathe; 01-28-2008 at 06:44 AM. |
| The Phoenician ![]() ![]() Join Date: Oct 2006 Location: Louisville, KY
Rep Power: 6 ![]() ![]() Thanks: 172
Blog Entries: 3 | Looking good man..
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. That which causes us trials shall yield us triumph, and that which makes our hearts ache shall fill us with gladness. For the only true happiness is to learn, to advance and to improve. None of this could happen without rejecting error, ignorance, and imperfection. We must pass out of the darkness to reach the light.' - The Primarch Fulgrim, Attainment of Perfection Tutorials: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Blog Entries: 4 | It never hurts to say please! I apologised for the fact that Im using my camera phone till my camera recharges! hope these are better (Have added some more details to the neck area) ![]() legs are nearly done-might have a full body pic by the end of tonight (If my missus doesnt kill me!)
| Corporal ![]() ![]() | Now that is better... You're skills with Plasticard are very good (Sorry I was meant to sound enthusiastic, not demanding )
Blog Entries: 3 | They are indeed Nano.. Yoiu should see some of the Archaic power armor he does.
| | #11 (permalink) | |
| Captain ![]() Join Date: Jun 2007 Location: U-S-A!!U-S-A!!U-S-A!!U-S-A!!U-S-A!!
Rep Power: 1 ![]() Thanks: 108
and hes been gone for a while so you know he is in to this project it already looks awesome and its just the torso
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ""A true patriot is a lover of his country who rebukes and does not excuse its sins." Frederick Douglass To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. * new items added 4/6/08 * ** tomb king army up for trade** | |
Blog Entries: 4 | Last one for today-he has legs now. Have used plasicard to bulk out the arm joints as he would look very thin up top otherwise! ![]() The Iron Warrior is for scaling obviously. Will do the arms and add a few more details tomorrow (still trying to figure out the arms!!)
| On The Warpath! ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: As a figment of my own deranged imagination, i don't actually exist anywhere. Or London, UK.
Rep Power: 5 ![]() ![]() ![]() Thanks: 178
Blog Entries: 1 | pert if you swoop in and win this thing at the last moment, which seems like a distinct possibility, i shall have to become unpleasent! ![]() |
Blog Entries: 3 | Come now hairy! You'd be tickled and you know it!
Blog Entries: 4 | I doubt I will-theres some quality production going on out there! And if you do Ill just give u a big hug, you big hairy lug you! ![]()
| | #16 (permalink) |
Blog Entries: 3 | It's almost cute.. I missed the teasing you big half mechanical monstrosity!! Come gimme a hug *hiding cream pie behind back with vortex grenade hidden in midst of it*
| The Emperor's Yesman ![]() ![]() ![]() | My GOD! It's kick-ass! And even then, it has no arms! And no paint! I'm scared of you, man!
__________________ My favourite quotes: "There is something infantile in the presumption that somebody else (parents in the case of children, God in the case of adults) has a responsibility to give your life meaning and point." ~Richard Dawkins "Man, when perfected, is the best of animals, but when separated from law and justice, he is the worst of all." ~Aristotle "Must not all things at the last be swallowed up in death?" ~Plato |
| | #18 (permalink) |
| The Emperor's Mercy ![]() ![]() ![]() | well, glad to hear pert's got a "warm" welcome back ! haha. good to see you posting again, and entering the contests no less ! this guy is really coming along, for all of SIX hours of work ! :] -ant
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SHOWBREAD. ANOREXIA/NERVOSA. MAY THIRTEENTH TWO THOUSAND EIGHT. |
| | #19 (permalink) |
Blog Entries: 4 | 6 hours of work, but Ive got a banging head ache, Ive glued most of my fingers together (and those that I havent Ive cut open), Ive got green stuff in the carpet, theres bits all over the spare room and my missus is in a really bad mood with me!! Worth every second! ![]()
| | #20 (permalink) |
| Corporal ![]() Join Date: Apr 2007 Location: Tacoma, WA
Rep Power: 2 ![]() Thanks: 55
Blog Entries: 1 | ok there pert you better keep these pics i'm gonna be waiting to see more plasticard tuts coming out of you now that your're back dagnabit!!! good work and hurry up dude!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. fe, fi, fo, fum. i smell imperial corpse scumm! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| | #21 (permalink) | |
| The Emperor's Mercy ![]() ![]() ![]() | Quote:
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SHOWBREAD. ANOREXIA/NERVOSA. MAY THIRTEENTH TWO THOUSAND EIGHT. | |
| | #22 (permalink) |
Blog Entries: 1 | all good signs of a hard day's modelling ![]() |
