Go Back   40K Terra - Warhammer 40k Forums > Warhammer 40k > General Warhammer 40k > Rules Help
Rules Help Just came back from a game and suspect your opponent was cheating? Or just stuck on an idea pertaining to rules? Well this place is designed to get questions answered.
Old 10-23-2007   #1 (permalink)
The Witchhunter
Drax's Avatar
Rep Power: 1 Drax is on a distinguished road
Send a message via MSN to Drax
Default Base Size - illegality issues
Browsing as I do on other forums, I have stumbled across a thread discussing the legality of base sizes.
As we all know, the rules clearly state that you must use a base no smaller than that supplied with the relevant model.
The opinion on this site is that the base sizes on the old metal Chaos Terminators, and for anyone using the original Obliterator models is now illegal, as the new versions of each now have bigger bases as standard.
My take on this is that it is rubbish. You use the old models with the base they come with, then they are legal, even if newer versions with larger bases have been released. By the letter of the rule book, you are complying with the rules.
This one obviously affects the Space Wolf players with the Wolf Guard in Terminator Armour. Using the metal versions, they are supplied with the ordinary size base, but the generic plastic Terminators come with the larger base these days. I know it is slightly different as it could be argued that there is a separate model set for the Space Wolf versions, but technically, they are both still loyalist versions of Terminators.
What are your thoughts on this?
Drax
Drax's MySpace
Drax is offline   Reply With Quote
Old 10-23-2007   #2 (permalink)
Lieutenant
Mart007's Avatar
Battle Brother
Rep Power: 1 Mart007 will become famous soon enough
Send a message via MSN to Mart007
I think your right. You can and only should be allowed to use the base supplied even if the mini changes. If you use a bigger base your putting yourself at a disadvantage as more minis can engage you in combat, so really if that happens I would let it slide if they really wanted to use that mini.
Follow my log (dont worry, it's a project log)
http://www.40kterra.com/forums/showthread.php?t=3223
Mart007 is offline   Reply With Quote
Old 10-23-2007   #3 (permalink)
Resident Greyhunter
Lord Erak Grimnar's Avatar
Rep Power: 2 Lord Erak Grimnar is on a distinguished road
Well technically it is illegal. It is annoying yes but unfortunatly it seems ilegel. However I wouldn't mind the much as its a valid reason but if it gets ridiculous I.E. demon prince somehow on the medium type bases then yer no way.
But for this I would make an exception although it does open up some cool conversion ideas.
Although itsstupid how you would want a bigger base unless you were really cheesy and wanted your marine squad to hold that much more ground.
I am Lord Erak Grimnar Wolf Lord of the Night Hounds and we shall stand and fight no matter the cost.
Here I am and here shall I die.
+++ attributed to Leman Russ at the Battle of Rising Fell +++
Lord Erak Grimnar is offline   Reply With Quote
Old 10-23-2007   #4 (permalink)
Lieutenant
Mart007's Avatar
Battle Brother
Didn't think of that. Also your at an advantage for pie plate attack with a bigger base!
As long as it wasn't a blatant attempt to be cheesy I dont think i mind to much.
Old 10-23-2007   #5 (permalink)
The Witchhunter
Drax's Avatar
well which is it? illiegal or seems illegal?
an old terminator has the ordinary base supplied as standard. even now, after the plastic versions have been released, were i to order an old metal terminator i would receive an ordinary size base, not the larger base that the plastic terminators use.
therefore, on a old metal terminator, if i used the ordinary size base, i would be using the base supplied and thus i would comply with the rules - therefore how is this illegal?
Drax's MySpace
Old 10-23-2007   #6 (permalink)
Hairy Hunter
Krom_stormbrow's Avatar
Rep Power: 1 Krom_stormbrow is on a distinguished road
Send a message via AIM to Krom_stormbrow Send a message via MSN to Krom_stormbrow
Th rule is (as I understand is you cannot go smaller than the base supplied with the model. But you can go larger - to the disadvantage of the player. You can quibble it's also a advantage... but it's marginal far outweighed by the disadvantage.
So increase by all means... just no shrinking. Also the metal terminators are still supplied n the small base. As for the oblits... it's the base supplied.
Krom_stormbrow is offline   Reply With Quote
Old 10-23-2007   #7 (permalink)
Lieutenant
Mart007's Avatar
Battle Brother
not so, when I'm firing a twin linked FP prism at old termies I can get two under focused beam (more if bunched together) as opposed to one.
But for the sake of the game I would let it go.
Old 10-23-2007   #8 (permalink)
Hairy Hunter
Maybe so... but them's the rules
I'll dig it out tonight.
Old 10-23-2007   #9 (permalink)
The Great Wolf
wolfpack's Avatar
Rep Power: 3 wolfpack will become famous soon enough
Send a message via MSN to wolfpack Send a message via Yahoo to wolfpack Send a message via Skype™ to wolfpack
Well as for the SW WG termies...I never liked the fact that Logan's base was of the 40mm variety while they were stuck on 25s...so am glad the new termies have the larger bases...
As to the rules...well I believe that the older figs on smaller bases will eventually be phased out...so playin with what you have is fine...of course you could always remount the WG termies on to the newer bases...LOL..of course thay aren't to scale so...it's all about judgement at this point.
I am Wolfpack, my fangs are long, my hair grey with age...I am The Great Wolf...I fight with bolter and Axe, my armies vast, my word final. A true son of Russ, my honor above all, I hunt the heretic, the xenos, and the witch and slay them where they stand!
My sons hunt our enemies,
slay them where they falter and bring their pelts to Fenris
wolfpack is offline   Reply With Quote
Old 10-23-2007   #10 (permalink)
The Witchhunter
Drax's Avatar
thanks wolfpack, but i think mart made the thread drift off point.
what i was getting at was that it has been claimed that the old terminators on the normal size bases are now illegal as they should now be remounted on the bigger bases.
i strongly disagree, it is on the base it was supplied with, and so is illegal.
am i not, by the letter of the rules, correct?
Drax's MySpace
Old 10-23-2007   #11 (permalink)
Filthy, Dirty Radical
experiment 626's Avatar
Honor Guard
Rep Power: 4 experiment 626 has a spectacular aura aboutexperiment 626 has a spectacular aura about
they're not illegal... you're using the base you're given by GW for that model. now if you were to say, buy an old metal termie and then slap a plastic on on the 25mm base you got for the metal one, then yes, you're definately cheating! (as we know that the plastic termies come with the 40mm bases.)
if you make a bitz order to get some of the old metal termies and you're sent the old 25mm bases, then you can use those - it's what you've been supplied with and basically 'told to use by GW'!
if someone tries to pull that kind of crap during a game by saying your metal termies must be changed to 40mm bases, then they're being an ass! (you used what you were given and that's all that the rule in question demands you do!)
cheers!
"Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!"
- Inquisitor Odion
experiment 626 is offline   Reply With Quote
The Following 2 Users Say Thank You to experiment 626 For This Useful Post:
Old 10-23-2007   #12 (permalink)
The Witchhunter
Drax's Avatar
thankyou.
it hasn't happened to me, but rather some guy on another forum has convinced at least 2 people to hack up their modelled/painted bases on their old metal chaos terminators and rebase them because a new version has been released with larger base sizes.
which as far as i am concerned is ludicrous, and for that matter bad advice on the part of the person stating this
Drax's MySpace
Old 10-23-2007   #13 (permalink)
The Great Wolf
wolfpack's Avatar
I must say that you are correct as it is what is supplied with the figs...not our fault GW doesn't have all their nuts in one bag so to speak...
As to the guy that is spreading seditious thought...hunt him down and flay his skin one layer at a time...this will end his raving lunacy
The Following User Says Thank You to wolfpack For This Useful Post:
Old 10-23-2007   #14 (permalink)
The Witchhunter
Drax's Avatar
i shall wolfpack, thank you. in fact, i may even stick him in a room with krom for an evening - that will make him think twice about making incorrect statements!
but in all serious, i just felt it was irresponsible and thoughtless as the ones taking his (incorrect) advice seemed to look up to the guy
Drax's MySpace
Old 10-23-2007   #15 (permalink)
The Great Wolf
wolfpack's Avatar
Perhaps they need to be directed to a forum where idiocy is dealt with in a harsher manner...perhaps here even..LMAO
Old 10-23-2007   #16 (permalink)
Just A Regular Joe. Again
SteveBerenyi's Avatar
Rep Power: 4 SteveBerenyi has a spectacular aura aboutSteveBerenyi has a spectacular aura about
Send a message via AIM to SteveBerenyi Send a message via Yahoo to SteveBerenyi
personally, i like mounting the old chaos termies on their 25mm then mounting that on a 40mm and doing a nice scenic base.
just me though.
WIN/DRAW/LOSS On The Battlefield
5 / 1 / 4
SteveBerenyi is offline   Reply With Quote
Old 10-24-2007   #17 (permalink)
Resident Greyhunter
just me though.
Thats what I was thinking about for conversion work and what I did with my SW conversion. Makes them look taller and standing on rough terrain.
Old 11-05-2007   #18 (permalink)
Trooper
Luisjoey's Avatar
Rep Power: 1 Luisjoey is on a distinguished road
Terminators with large bases is crap :P
why they were changed?
I serve the God Emperor!
Visit Calabozo Criollo Forums
Venezuelan site for RPG and Miniatures
Luisjoey is offline   Reply With Quote
Old 11-05-2007   #19 (permalink)
Adeptus Arbrites
iNsOmNiAc'S dReAm's Avatar
Rep Power: 1 iNsOmNiAc'S dReAm will become famous soon enough
thankyou.
Well I have a solution...
Some of the guys down here in hawaii just took their old termi models, base and all, and glued the whole thing to a larger base. It may not look very pretty but it works and its simple. Also a large bag of 40mm bases are pretty cheap.
As I understand it, down here all termi models old or new must be on the larger bases in order for them to be tournament legal. Of course I may be mistaken.
iNsOmNiAc'S dReAm is offline   Reply With Quote
Old 11-05-2007   #20 (permalink)
The Witchhunter
Drax's Avatar
but that makes it a tournament 'house rule' then surely?
not what the rules class as legal or not legal.
Drax's MySpace
Old 11-05-2007   #21 (permalink)
ok from what i can tell (and a lot of this is breaking the cardinal rule of 40k... I.E. apply common sense to rules interpretation.)
You can use the old termie bases. as the rules specifically say "The Base a model is Mounted on can be NO SMALLER than the base the model was supplied with."
IMO the old termie bases are still legal. what this does to squad coherency is minimal, but what it does to template weapons is very well, Ugly as fewer will ever be under it.
HOWEVER this is also balanced with the deep strike rule.
as you must put them in circles touching bases.... the smaller bases take up less space. so you have less chance of ever landing on terrain or other models.
My 2 cents.
Steve.
5 / 1 / 4
Old 11-08-2007   #22 (permalink)
Primer
camo's Avatar
Rep Power: 0 camo is on a distinguished road
The key word in the rule is "was". it the rules stated ""The Base a model is Mounted on can be NO SMALLER than the base the model is currently supplied with.", then you would have to change it, but if the model was supplied with a smaller base when you got it, it's legal.
"It would scare the **** out of al Qaeda if suddenly a bunch of black ninjas rappelled out of helicopters in to the middle of their camp. It would get us an enormous deterrence and show those guys we're not afraid."~Bill Clinton
camo is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
