| Notices |
| Rules Help Just came back from a game and suspect your opponent was cheating? Or just stuck on an idea pertaining to rules? Well this place is designed to get questions answered. |
| Resident Greyhunter ![]() Join Date: Nov 2006 Location: Wherever the wolves go
Rep Power: 2 ![]() Thanks: 16
| Ok these questions have been bothering me for a while. 1. Do you need to take a role to wound if the weapons str is double or more than the unit its firing ats toughness. 2. Do you have to roll to wound against a vehicle then move to the pentraction or glancing. 3. Can drednaughts, vehicles and terminators move and still shoot with heavy weapons that turn 4. when firing with a flamer at a building do you have to say which floor is it every unit under the flamer whether be first or thrid floor thanks in advance
__________________ I am Lord Erak Grimnar Wolf Lord of the Night Hounds and we shall stand and fight no matter the cost. Here I am and here shall I die. +++ attributed to Leman Russ at the Battle of Rising Fell +++ ![]() Last edited by Lord Erak Grimnar; 04-05-2007 at 08:30 PM. |
| Corporal ![]() Join Date: Nov 2006 Location: Titan
Rep Power: 2 ![]() Thanks: 2
| 1. if you hit him and your weapon is instakill you still need to roll a d6. if you roll a 1he is alive as a 1 is always a failure or crew stunned. 2. no. roll to hit. then roll strenght. then roll for penetration. 3. vehicles can as long as they moved only 6 inches. there is a page in the rule book with more details. dreadnaughts maybe. termies i seriously doubt it. 4. in CoD yes. in regular 40k just try to place as many under the template. hope that helps
__________________ ![]() ![]() |
| The Ruler of Earth ![]() ![]() Join Date: Nov 2006 Location: Good old England!
Rep Power: 2 ![]() Thanks: 19
| 1. Do you need to take a role to wound if the weapons str is double or more than the unit its firing ats toughness. You always need to roll to wound- if the weapons strength is double the units toughness, it simply means that if the model it is shooting at has more that one wound and it loses 1, it loses all of them. Remember, a roll of 1 to wound is always a failure too. 2. Do you have to roll to wound against a vehicle then move to the pentraction or glancing. You don't roll to wound against a vehicle- you use armour penetration. You roll a D6 (or 2 D6 in some cases) and add them to the strength of the weapon. If the number is equal to the armour value of the side the weapon is firing at, it is a glancing hit. If it is more, it is a penetrating hit. There are some special exceptions to this rule (for instance, if AP1 weapons roll 2 D6, and if they get a glancing hit it is moved up to a pentrating hit. Also, if a weapon has AP- it means that they can only score glancing hits, even if it would be a pentrating) 3. Can drednaughts, vehicles and terminators move and still shoot with heavy weapons that turn Dreadnaughts can move 6 inchs and fire one main weapon and all their primary weapons. They can't move anymore than that. Different types of vehicles have different rules for firing weapons, depending on whether they are fast, tank, skimmer, and others. Heavy weapons are just the same as normal weapons for Vehicles- they can move and shoot with them just as if they were an Assault weapon. Terminators can move and shoot with Heavy weapons too, due to their special armour. 4. when firing with a flamer at a building do you have to say which floor is it every unit under the flamer whether be first or thrid floor To that I have no idea- I've never had that before. I'm guessing you place the flame template, and any model underneath (whether they are on the first or fourth floor) are hit, as that is what usually happens with blast templates (though I could still be wrong, I think another member needs to put an answer)
__________________ By trying we can easily learn to endure adversity -- another man's, I mean. - Mark Twain Last edited by Killermoose; 04-07-2007 at 01:46 AM. |
| thanks to question 4 I know in CoD i is based on floor but in a normal game im not sure
__________________ I am Lord Erak Grimnar Wolf Lord of the Night Hounds and we shall stand and fight no matter the cost. Here I am and here shall I die. +++ attributed to Leman Russ at the Battle of Rising Fell +++ ![]() |
| Thread Tools | |
| Display Modes | |
