| | #1 (permalink) | |
| On The Warpath! ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: As a figment of my own deranged imagination, i don't actually exist anywhere. Or London, UK.
Rep Power: 5 ![]() ![]() ![]() Thanks: 178
Blog Entries: 1 | yo to you all i'm trying to buy some plastic rod of the net but i can only find stuff with measurements listed in imperial units, and being a metric thinker i have no idea that they mean. could someone explain the following dimentions to me in mertic measurements?... .030 .040 .080 .100 1/8 1/16 3/64 and yes, i am aware of the irony of an englishman not understanding the imperial measuring system ![]()
__________________ Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |
Blog Entries: 1 | so .04 is roughly 1mm, .08 is about 2mm and .10 is 2.5mm?
| Confused and Enraged ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: South-east Ireland
Rep Power: 2 ![]() Thanks: 13
| Thats about right. What exactly are those measurements for? They seem mighty small... ...If your confused about this you should try designing an urban terrain field on a 6x4 foot board using a program that has ALL measurement in mm (no matter how big the measurement)...
__________________ The thing that inspires men to kill is Hatred. -Sun Tzu To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Vote On The Battlefield: For any concerned I'll be online much more often once exams end friday 23rd. |
| | #6 (permalink) | |
Blog Entries: 1 | lol. there's a clue in the thread title, they're for the width of plastic rod.
| Tyrant of Moray ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Eye Of Terror
Rep Power: 3 ![]() ![]() Thanks: 19
Blog Entries: 4 | Try working on an aircraft that has both Imperial and Metric bolts on it! And then to confuse matters even more some of the bolts have a different thread system to the others!!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Experts in Siege Works....we also do Patios and Drives To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| | #9 (permalink) | |
Blog Entries: 1 | ok cool, thats good to know. i'm mostly gonna be using this stuff for weapon shafts and extending the wheel mounts on sm bikes.
| Banned | well, the spokes should be at last 0.10, probably bigger depending on whether you want them to look heavy duty or not. and regarding the weapon shafts, it depends on the models - empire spearmen and marines would have different thicknes poles, though im assuming youll be using them for the space wolfs I (by assuming i may be making an ass out of you and m..ing), in which case 0.08 shaved down would be good for termies, and 0.06 might be ok for normal troopers and things like axes |
| | #11 (permalink) | |
Blog Entries: 1 | yeah this is for the wolves. the spokes will be using the bigger size, mostly .10 with a bit of 1/8. the weapon shafts will be at least .06, probably .08 and partially sheathed in gs for grips and stuff.
| | #13 (permalink) | |
Blog Entries: 1 | yeah i found that out the hard way when i tried to fix a braid to a chin ![]()
| Lieutenant ![]() Join Date: Jan 2007 Location: Ireland
Rep Power: 2 ![]() Thanks: 17
Blog Entries: 4 | Hmmm, I must remember to look this up at some point...
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. The opinions posted above are solely the property of the Ides account and are in no way representative of those views held by the staff of this forum. "I'd consider him dangerous...he's too hairy not to be." Phil Ken Sebben For sale: One soul. Mint Condition, never been used. |
| Banned | also yahoo, i must recomend that you pin the rods. they will stick pretty well with polystyrene cement, though a pin running through one side of the weapon, the hand and the pole and any other parts where two different bits meet will ensure a really strong bond... great if youre as clumsy as i am when painting your models! |
| | #16 (permalink) | |
Blog Entries: 1 | **engage sarcasm mode** thanks D_C i didn't realise that, i was just gonna stick em on with bubble gum and hope for the best **disengage sarcasm mode** ![]() in all seriousness its good advice. i was planning on drilling straight through the hand and using one pin to secure both parts.
| | #17 (permalink) | |
| The Phoenician ![]() ![]() Join Date: Oct 2006 Location: Louisville, KY
Rep Power: 6 ![]() ![]() Thanks: 172
Blog Entries: 3 | Quote:
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. That which causes us trials shall yield us triumph, and that which makes our hearts ache shall fill us with gladness. For the only true happiness is to learn, to advance and to improve. None of this could happen without rejecting error, ignorance, and imperfection. We must pass out of the darkness to reach the light.' - The Primarch Fulgrim, Attainment of Perfection Tutorials: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |
| | #19 (permalink) | |
Blog Entries: 1 | lol. dude your help is most valued and appreciated, but you know i can't resist a good opportunity when i see it . besides i'm sure you'll add it to the list of grudges you have against me![]()
| | #20 (permalink) |
| Captain ![]() Join Date: Jun 2007 Location: U-S-A!!U-S-A!!U-S-A!!U-S-A!!U-S-A!!
Rep Power: 1 ![]() Thanks: 108
| "imperial" system here in the USA we call it the english system and for an englishman not to know it is really ironic we know we are the only ones that still use it but i have a question do you guys play 40k using inches or do you use metric? ive always wondered that
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ""A true patriot is a lover of his country who rebukes and does not excuse its sins." Frederick Douglass To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. * new items added 4/6/08 * ** tomb king army up for trade** |
| | #21 (permalink) |
Blog Entries: 4 | inches, considering that's what it says in the rule book...
| | #22 (permalink) |
| Fantasy and 40k are all inches, as well as most of the specialist games. Inquisitor measurements are in yards but these are represented by whatever scale is appropriate for you (1yard = 1inch/cm etc) LOTR has measurements in both imperial and metric.
| | #23 (permalink) |
| heck i was just asking you never know whats going on over the pond i figured it was in metric hell they might have produced 2 different rulebooks i didnt know but now i do since you guys call soccer football and all types of other things we americans think is backwards j/k but for real thanks for letting me know
| | #24 (permalink) |
| What the hell is soccer??? I've never heard of this word in my life... ![]() And no wonder you americans have so many car accidents...you all drive on the wrong side of the road. And if I don't shut up now I'm gonna get myself in trouble. ![]() So anyway...yeah, one rule book for both continents, GW were too lazy to right two.
| | #25 (permalink) |
| you know soccer you guys call it football you your guy Beckam came over to play in MLS Major league Soccer and we get in so many wrecks cuz we can just go and get another car no problem and relax dont get your knickers in a bunch its a joke cousin smile and understand that its all fun and thanks for explaining the whole book thing im wondering do they print it in other languages?
