| Corporal ![]() Join Date: Oct 2006 Location: ConCreTe JuNgLe (southern California, US)
Rep Power: 2 ![]() Thanks: 3
Blog Entries: 21 | So fellers, me first match is today at 3 pm Pacific, so i have bout 2 hours to prepare. heres me list, i guess....my first one...also might need help with it... HQ Sm Commander Stormbolter Iron Halo Power Sword total:105 Troops 1st Squad 8xmarines w/ bolters 1xmarine w/ RL 1x Seargent terminator honors, chainsword, powerfist total:190 2nd Squad 8xmarines w/ bolters 1x marine w/ flamer 1x Seargent terminator honors, chainsword, bolt pistol total:173 Fast Attack 3rd Squad 3x Assault Marines 1x assault marine w/ plasma pistol 1x Seargent terminator honors, power axe, combat shield Total:145 Grand Total:613 pts So anyway today i play my first match against a guard army, my secon match is against crons most likely.... ANY HELP IS APPRECIATED thanks Last edited by Baron Spikey; 10-20-2007 at 02:46 PM. Reason: not allowed to post individual pt costs |
| Lieutenant ![]() ![]() Join Date: Oct 2007 Location: UK
Rep Power: 1 ![]() Thanks: 102
Blog Entries: 1 | I'm no Marine expert, but that seems pretty balanced in my view. SMurfs exel in small pt games so dont worry to much I think your ok.
__________________ ![]() ![]() Follow my log (dont worry, it's a project log) http://www.40kterra.com/forums/showthread.php?t=3223 |
| | #5 (permalink) | |
Rep Power: 4 ![]() ![]() Thanks: 40
| well, let's see here... first off, just a quick heads-up; don't post individual pts costs/upgrades as it is against GW's IP policy. just list the final unit totals. Quote:
the necrons are easily handeled if you keep one general rule of thumb; pick on 1 unit untill it's totally wiped out! don't try and shoot up a bit of everything because usually the 'crons will just stand right back up... as long as you wipe out a unit and there's no other 'active' model of the same type within 6", they don't get the 'we'll be back' rolls! top threats are; destroyers, wraiths, tomb spyders. however, in general stick to targeting the models that have the 'necron' special rule. if the total number of 'necron' models ever drops below 25% of their starting number, then the whole army phases out! cheers!
__________________ "Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!" - Inquisitor Odion ![]() Last edited by Torquemada Coteaz; 10-20-2007 at 02:49 PM. Reason: Remove individual points costs | |
Blog Entries: 1 | Depends on what army your playing. Get your Assault squad in as quick as pos. You wont be up against to much armour at this point level which makes your 3+ save invaluable. The key is be bold, dont hang back get your bolters into rapid fire range (that hurts) you should be fine. Being an Eldar player I have been up against a few C/SMurf armies, they are more forgiving at this level than other armies so use your advantage.
Blog Entries: 21 | I do have a RL in first squad RL=Rocket Launcher... Also, all those units i should have ie: Rhino, chaplian, i aint got no more money captain!!! |
Blog Entries: 1 | You may think about dropping some wargear and squeezing a Rhino in there, mobility and Marines is frightening - in fact I would do that.
| | #9 (permalink) | |
hell, they can even add-in a basilisk w/indirect fire on top of the russes too... mind you, if the guard player does that, by all means tell him/her off as that's pretty low... cheers!
__________________ "Who are you to question my methods?! A 'Puritan' is simply a coward who hides behind a veil of pretended faith and denounces his loyal brother as a traitor out of simple jealousy!" - Inquisitor Odion ![]() | |
Blog Entries: 1 | Could you squeeze a Dred in there that may help? but could be a drain. A Rhino is very handy in that you can use it as mobile cover as well, that can be invaluable
__________________ ![]() ![]() Follow my log (dont worry, it's a project log) http://www.40kterra.com/forums/showthread.php?t=3223 Last edited by Mart007; 10-20-2007 at 02:29 PM. |
| High Lord of Terra ![]() ![]() ![]() Join Date: Nov 2006
Rep Power: 2 ![]() Thanks: 59
| if its a 600pt match then yes unless your opponent is cool with you going over the pre-arranged limit. Cut back on your commander, he doesn't need that Iron Halo but do keep the p.weapon as he might not be the best Space Marine HQ in combat but he's still extremely good when compared against IG/Tau leaders in that respect and it would be a shame for him to hit with most attacks, wound with most of those and then fail to kill his enemy because they rolled their armour save. Its up to you to decide what role he's directly going to play but i'd suggest changing the S.bolter for a bolt pistol (unless you've already modelled the storm bolter in which case dont worry). Ignore the others when they say add certain things- as you've already mentioned, you dont have the time! Swap the Sgts over between 1st & 2nd squad as 2nd squad is more assault oriented and could really benefit from the power fist. other than that it difficult to alter your list more than this in the time available. |
| Adeptus Arbrites ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2006
Rep Power: 2 ![]() Thanks: 14
| ok, im more of a troops guy, so heres what i would do: drop terminator honours and wargear on sargeants, drop iron halo and storm bolter on HQ. that gives you about 90 points to play with. give the HQ a bolt pistol, add 2 assault marines to the squad and give the assault squad melta bombs. this way, you have more assault marines and some measure of anti-tank. youre also only 3 points over 600 ![]() if the guy is a D#(* and has a couple of tanks i would then switch the flamer in the tac squad for a melta gun. thats just what i would do based on how i like to build my lists. some people like the built up seargants (i kinda have the tyranid mentality with all of my armies: more gribblies!) |
| Adeptus Arbrites ![]() ![]() Join Date: Jul 2007 Location: socal
| i kinda agree with dan in thios one specaly low point games the more guns you got the more dice you roll.
__________________ Let the galaxy be illuminated, As it burns!!! ![]() |
| | #16 (permalink) |
| Master Procrastinator ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: As a figment of my own deranged imagination, i don't actually exist anywhere. Or London, UK.
Rep Power: 5 ![]() ![]() ![]() Thanks: 224
Blog Entries: 1 | well i guess you've played the game already...how'd it go?
__________________ WHY SO SERIOUS! ![]() Howling At The Moon - A Truescale Space Wolf W.I.P Black Legion W.I.P Frozen Leaves Falling to Cut - eldar W.I.P |
| The Great Wolf ![]() ![]() ![]() ![]() | yeah how did it go...600 points...I don't think I've ever played a game that small...LMAO ![]()
__________________ I am Wolfpack, my fangs are long, my hair grey with age...I am The Great Wolf...I fight with bolter and Axe, my armies vast, my word final. A true son of Russ, my honor above all, I hunt the heretic, the xenos, and the witch and slay them where they stand! ![]() My sons hunt our enemies, slay them where they falter and bring their pelts to Fenris Last edited by wolfpack; 10-21-2007 at 12:39 AM. |
| | #18 (permalink) |
Blog Entries: 21 | Ive proven victorious lads.... my first macth against anyone went quite well.... I only lost 3 marines and 1 assault maarine. He used 3 sentinals, which just dropped like ten ton flys, then his guardsmen were tereibly weak in close combat, it was beautiful. i just assaulted a lot haha during my first match the dice gods blessed me so, then i played the cron dude....didnt go to well...lol, any tips on fighting crons? haha |
| | #19 (permalink) | |
in terms of which units to gun for first, i usually prioritise as follows; 1) destroyers; they're fast and dead shooty! but there's only ever 5 in a squad so they make an easier target than say the 12-20 strong warrior units! 2) wraiths; again, they're fast and lethal in combat. (well, they tie you up good!) use their small squad size to your advantage and take then down asap! be sure to use just basic guns like bolters/heavy bolters as they have those 3+ armour/3+ invulnerable saves. 3) monolith. a good necron player uses it to re-roll his/her WBB rolls. if they start doing that, then the 'lith needs to die fast or the necrons will simply out-last you. cheers!
| Thread Tools | |
| Display Modes | |
